SYNC 2.3 update is p%^$& me off...
So I've tried doing the update most of the afternoon.
Tried OTA....connected to WiFi at the house....scans and then says incomplete.
Tried downloading, get the files, unzip etc...plug in the thumb drive and it says error, if it happens again, call the number.
I look at the files on the USB and they are not the same as the SYNC site as far as whats in the SYNCMYRIDE folder.
Anybody have any pointers?
clean USB formatted correctly? Yep, FAT32 like it asked for
Unzip on your computer and place all the files in the usb? Yep
Insert in the USB slot on the truck and then start it and it should automatically start the download So the truck was on when I put the thumb drive in, would that make a difference?
Took mine about 20 minutes to finish. It showed that it was downloading at the top of the screen.
I know I did this a couple of times in my '13 and it worked fine. Not sure what the issue is here.
Received 6,620 Likes
on
The files also have to be in the same order when you put them on the thumb drive as they are when they are unzipped to your desktop/laptop. You definitely have to follow the directions exactly as Ford has laid them out or it will not work.
Mine took about 20 minutes to download and upgrade in my truck. My truck was running when I did the upgrade, per Ford's instructions.
I have a Mac and my 2.3 update went over very well without any problems.
One must follow these download instructions to the letter and the files "MUST" be loaded to the thumb drive in the exact order they are unzipped on your desktop.
To make sure, just drag each file one at a time to the thumb drive and you should be good to go.
Unzip the file on your desktop computer. Drag each of the files to the correctly formatted flash drive and let them copy over to it. Eject properly and remove drive.
Place in USB port of truck and start. The battery saver will time out unless it's been extended in FORScan so leave the truck running. I was getting pissed at seeing no messages at the top of the screen so I walked away and returned about 40 minutes later. It was done. Restart the truck and update should be complete.
