Mixing Wheel Bearing Grease
Finishing the front end conversion on my truck to older style cone-roller bearings.
I ended up finishing a tub of grease and having to pick some up from a different auto parts store.
The first tub I used, was Napa brand wheel bearing grease for vehicles with disk brakes. Its lithium based.
The next tub I picked up is the same, but red in color, and is also lithium based.
I shouldn't have anything to worry about, mixing two different colored lithium based greases, should I?
Seems a bit silly to ask, but I don't want to find myself on the side of the Alaskan highway, knowing I could have avoided a problem with a 5 minute post on FTE.
I've always been told not to mix different greases. While they are both lithium based and probably would be fine, I have found the red doesn't hold up near like the off-road/Marine grease does.
I'm not at the house right now to look at my books and give specifics, but if I remember when I get home I'll take a gander at em for ya.
Mixing lithium and calcium-based grease will cause you all sorts of major problems but since the base is the same in this case you will be ok.
I accidentally bought a case of polyurea grease once and after using it (and mixing with some calcium sulfonate grease), it turned to the consistency of.....granite. That was a fun bucket pin bushing relacement a few weeks later.
TexasGuy001
Oil & Lubrication
03-28-2011 10:02 PM
ksmith203
03-26-2007 09:03 PM
96f150
08-12-2005 06:17 AM
