Headlight adjustment. Sorry!
I am looking for the headlight adjustment procedure for adjusting my headlights on my 2017 F350. I am sorry because I know there are old post’s on this but I can’t seem to find what I am looking for. I just had a 2” level installed on my truck today and I got flashed a lot before the level so I figured I better re-adjust my headlights because they will be even higher now. Thanks.
I did mine after leveling. I parked it on a level surface in front of a wall/garage door. Turned on low beams...put masking tape on the wall where the top area of the light beam was shining.. measured down 2 inches put another piece of tape.. adjusted the light to the lower piece of tape. Works fine.
Careful with those headlight adjusters, at least on the LED lights. The mechanism doesn’t move smoothly and I broke both adjustments cables trying to lower them. Basically the amount of force required to snap the cable is less than the amount required to move the headlight. Haven’t taken it in for warranty replacement yet...
Just how firm do you need to be with those headlamp adjustment screws? I have a '19 F250 and attempted to adjust mine but noticed they are tight (as s&i&) and not wanting to break or strip them I stopped. Am I missing something or will they withstand a firm/hard turn? Suspect I may be better off taking it to my Ford dealer and having them do it.
Just how firm do you need to be with those headlamp adjustment screws? I have a '19 F250 and attempted to adjust mine but noticed they are tight (as s&i& and not wanting to break or strip them I stopped. Am I missing something or will they withstand a firm/hard turn? Suspect I may be better off taking it to my Ford dealer and having them do it.
derherr65
01-09-2007 04:24 PM
