Towing with 4" straight?
Some of you know i had been considering going to a 6.7 because i haul a 15k 5th wheel now. decided for now to stay with my ole trusty 6.0. Ive been looking at ways to help manage the EGT and was considering a exhaust and possibly bigger turbo. Currently I have stock pipes with the CAT removed and a Walker BTM muffler on it. It sounds fine as I dont really want the drone or loud truck while towing. I see 4" is really popular on the boards but what about while towing? I guess I could go 4" and another Walker type muffler? What do you all think?
DW
DW
I'd stay with what you have for a few reasons...
Turbo lag- when you go from a 3 inch downpipe to a 4 inch downpipe, it takes more time for your turbo to spool leading to a lag when you step on the pedal cruising or from a stop.
Torque-When you go to a 4 inch downpipe, the torque you bought the diesel for is now higher in the RPMs. With the 3 inch downpipe, it doesn't take much to spool the turbo to get and keep the load moving. With a 4 inch downpipe, it has to fill the downpipe with enough exhaust and back pressure to spool the turbo before you can build the proper torque you need and the engine was designed for.
Fitment issues-I've noticed that alot of people myself included have had fitment issues with the 4 inch downpipe. It tends to rub and rattle in certain spots, but depending on the kit, it may not. I learned this with my 4 inch downpipe, it never did fit right and would rattle against the spring shackle.
Performance-Though irrelevant to your situation, I managed to put down 411hp and 756 torque on Gearhead's SRL Extreme. My buddy who has an '05 F350 SRW 155/30 injectors, Atlas 40 FICM, Stage 2 turbo, and a huge exhaust, didn't put down much more than I did. That pissed him off, but it got the point across that all the overkill he put into his truck didn't make too much of a difference.
I learned all this from my experience with my truck as well as from one of the two engineers who wrote the programming for these trucks. He confirmed alot of what I learned and gave me alot of insight on getting these trucks to perform their best. So if you're concerned about EGTs, the most I would do is a cat back exhaust with a cat delete.
DW
DW
When I got my X it was stock with 13k miles. I had bad and inconsistent hesitation. Pulling out in traffic was a challenge. So I removed the cat. Got a lot better. Put on an MBRP SS turbo back 4” exhaust with muffler and no cat. Since I did that 11 years ago I have never had any turbo lag. In fact my turbo is constantly turning. When my truck is idling, it sounds like a running APU on a commercial airliner. All it has to do is adjust the vanes to provide the requested boost.
I belleve that is the reason why the 6.4 had twin turbos. The small one kept the big one spinning so there was no turbo lag like the stock 6.0 had.
Ed
Ed
The Atlas 40 goes on the FICM, Matt's tow tune goes on the PCM.
When used together, the truck responds much better, but you have to watch EGTs when towing heavy unless you have an upgraded turbo to keep things cool.
Case in point, I used a buddy's '04 F250 to tow a friends Mercedes Benz home from the dealer. I towed with SRL Extreme since he didn't want to change it, but with his Stage 2 turbo, EGTs never went past 1100 degrees.
on
I run a 4" turbo back and tow a 16k 5ver and it is not a problem at all, I found a drop of 300 degrees on egts on average.
You have no extra lag, no loss of torque. Back pressure on turbo engines is 2 fold you have pre turbo which does not change at all with a larger turbo back exhaust as your turbo is the restriction and you have post turbo back pressure and the less the better. On Natural aspirated engines you can definitely tune your engine for a RPM range by sizing it for maximum velocity/flow.
DW
DW
