7.3 Won't run after repairs
Hi all, new to this forum, new to forums in general. Been lurking on it for a while now to see if I could find the answer to my problem.
Truck is a 2003 F350, 7.3L with 180K on it. Only mods are intake, exhaust and DP tuner.
Had a bad leak from HPOP, base gasket/seal was the culprit. Bought a reseal kit to repair. Resealed it and replaced the IPR at the same time. Did everything to the riffraff procedure that came with the kit, fired the truck up and ran great, no more leak. Drove the truck around town for a while, beat on it like it was rental, ran great then parked it. A couple days later I fired it up, started right up, everything seemed fine. After a few mins of running the truck started stumbling, super rough idle, no power, hardly any pedal, sounded like it was running out of fuel. Shut it off, started up again with same symptoms right away. Poked around looking for something off around the fuel bowl, HPOP area, nothing stood out. Started it back up, same rough running symptoms, cracked the fuel bowl drain and it smoothed out for a bit, leading me to believe I've got a seal issue with the fuel bowl. Ordered a fuel bowl O-ring kit from diesel O-rings, put in all new O-rings, new FPR and billet FPR cap from Diesel O-rings. Fired right up and ran great for a minute or two then same symptoms came back.. Drained the fuel bowl to check everything out, made sure the check valve was operating correctly, replaced everything, cycled the key a few times to fill up the fuel bowl and she fired right up and ran great for a minute then back to running rough... Am I sucking air from somewhere?? Valley is dry, no leaks around the fuel bowl, fuel bowl fills up fast (lots of pressure). I did notice a small 1" puddle of diesel on the shop floor after a 12 hr period, not sure if that's residual from when the tube fell off the fuel bowl drain tube and coated everything with diesel.
I'm stumped at the moment. I can drain the fuel bowl, remove filter and replace, refill and start it right up.. for a minute or two... Any ideas on what to do or look for would be greatly appreciated! I haven't scanned it, I don't have a scanner like AE, don't have any data or codes. CEL does come on when it starts running rough. ICP looks good, no oil in it. Tank is half full, oil and filter is fresh (changed when did the HPOP reseal), HPOP reservoir is full, fuel filter is motorcraft. No smoke when cranking or started. GPR is new, Batteries are taking a beating with trying to figure this out but got em on a charger. HELP please!
What brand of ICP are you running? I had an IPR issue a few years ago right after I bought my truck. I threw it in a shop (being a diesel rookie) and the shop wanted to replace every part but the IPR - ICP being the first part. Long story short, I got it back and maybe a week later it pulled the same thing as your truck is. Turns out after the shop replaced it under warranty with no change, I bought a Motorcraft from the dealer and the issue was fixed. Also check the pigtails on the ICP and IPR.
