Install factory AC in non ac truck
My parts truck (1990 f150) is an ac truck im throwing around the idea of swapping it into my 89.(non ac custom trim)
I already have the under hood ac components removed as one piece (didn't open any lines) The motor is being swapped Into my truck so the harness has the clutch plug.
How much other then the under hood parts would I need to change? Just the HVAC switches?
on
Depends on how much trouble you want to go to. You will need the entire dash assembly as the vacuum hoses and wiring harness are going to be different, and those are all attached on the back of the dash. If the donor dash is the wrong color, you can swap everything over to your dash OR you could just add a switch to turn on the A/C compressor when you want A/C. Your existing dash registers will work to deliver the cold air, it just wont look "factory".
So long story short swap controls in the cab and install the under hood components? Seems simple enough
Have a feeling mechanic is lying.
everything plugged right up. Just took it to the shop to do the Freon and they kept it for over a week saying that my ac still isn’t working but everything’s already plugged up. So who knows. Literally all connectors plugged up. They don’t really update me but say they’re working on it, bout to go show up and catch them with their pants down.
mine is a 1994. So all wires are there. And I know there’s a connection to the compressor cause I could jump it, so doubt there’s a bad connection. My trucks also in good condition so highly doubt there’s a torn wire from pcm to relay, but who knows. I can try using a test light but they’ve been holding it.
teamshadyinc
05-28-2010 03:18 PM
Monster 78 F-150 4X4
11-24-2003 12:55 AM
