Need help shining 68 Grill
not sure if this will work or not but it,s worth a try. on the aluim. trim piece that is on the tailgate that says Ford. i took a rag and soaked it with some paint thinner not paint stripper. and wiped the finish off of it. when you are done it will have a shine that will look like you buffed it out. but you did not. i have used this on two other f-100 tailgate trim pieces. but i have not tried it on a grill yet.
Read through these and your question should be answered.
https://www.ford-trucks.com/forums/9...ll-polish.html
https://www.ford-trucks.com/forums/1...storation.html
I have used the Crystal Draino method of stripping referred to in these threads. It does work, but you have to be very careful with it. Take the safety warnings seriously: work outside, wear goggles, gloves and long sleeves and be sure you don't 'cook' your parts too long in the lye.
And invest in a buffing wheel.
I found an AC coil cleaner that has a higher lye content then easy off .
I used this on my wifes Elcamino Aluminum trim . worked very well .
https://www.johnstonesupply.com/stor...ep?pID=B82-559
Don't use the liquid stuff. Use the crystals in water. Try diluting 1/2 cup Drano per 1 gallon of warm water. Make sure you keep an eye on the parts as the solution will eat through the anodizing and go to work on the metal.
Drano contains lye, which will burn skin, especially eyes. Wear protection and avoid enclosed spaces!!!
As others have said, start with 400 grit and go to 600, 1200 and 2000 then the polishing compounds.
