Kicker door speakers and center channel
Just FYI, that dynamat isn't going to do anything for you. You need to cover as much of the door skin as you can to get benefits from it. Did you leave the stock tweeters hooked up? Any reason you didn't do components up front?
I've got some Focals sitting in the garage, can't wait for my amp to show up.
Actually, you are wrong. The dynamat will act as a gasket between the doorskin and the MDF. This will prevent vibration and distortion.. but what do I know. I’ve only been installing car audio for the last 10 Years.
You installed stereos for 10 years and you replaced component speakers with coaxials? Why? Did you unhook the stock tweeters at least or do you have off axis highs fighting each other?
Sorry man, not trying to **** on your thread. It just raised so many questions for me.
To get the most out of your speakers I would add speaker baffles and seal the doors. https://www.crutchfield.com/p_237XT6...h.html?tp=2809
Sure, it'll work as a gasket, (it's not doing anything for distortion) but why not use any number of other materials that were designed for that? Dynamat will stiffen your door skin and dampen power robbing resonances. That's what it's best at and designed to do. Why not apply it the way it was designed if you've already gone through the hassle of taking the door panels off? That's where you reduce distortion and resonance. You have to dampen that entire plane.
No need to apologize- this is the internet. There will always be some D-bag that has some bigger or better idea for your build. Thanks for raising your questions/ concerns. Now, move along.
lol you guys, anyway, remember, any retail store with buying power can order from a company with the specs to make it cheap but keep the name, home depot and lowes do this with appliances and some of us buy them not knowing which ones they are. I only know a few that we deal with in my businees there are alot more. ford can order a turd from sony, put it in the door and still day it has a sony turd system. i still don't understand the odd mounting screw locations of those speakers. so annoying.
You're right, I'm in the wrong here. I re-read my posts and I came off like the d-bag. Nice upgrade, sorry for asking.
