Another cab followed me home
I heard a rumor they are glued down. You can try a surgical sir inge ( cannot spell it tonight) loaded with a solvent such as rubbing alcohol. Carefully inject it in as many areas you can starting from edges and working your way into it deeper to remove the glue. I have not tried it and this may be a case where a repop would be easier since this one needs repairing anyway.
Dash pad
Nice score.. Is it hard to remove the dash pad? Any tricks on how to remove it.? Never removed one before. Another question. Are those cracks repairable? There is one at the local picknpull in similar condition. Not sure if I should grab it. Any advice is appreciated . ,Doug.
The trim is not that hard to find around here evedently. Lol. Thats just about all thats left from the rusty trucks in the salvage yards near me. I have already picked up 5 extras. The clips on the other hand is a different story.
Yeah, great score. How is it for rust?
I removed my UV-baked dash pad with a plastic putty knife. There's not much glue under there, but it's tough to clean off. I used many applications of Goo-Gone. Don't use Goof-Off, it will remove the paint too.
I found nice paint under mine too.
Eric
Eric
I’m hoping to reuse that pad in another cab so I’ll take my time removing it. I haven’t looked close for rust yet but the lower drivers cowl is rusted out. I think you can see that in one photo. The gutter is clean and floor seems solid through the carpet.
I really wish this was a step cab so I could use it on my 65 4wd.
Assuming you are not going for a correct restoration since you plan to likely modify the frame/engine mounts for a power steering conversion? I'd go with the best cab you have and add the new front frame mounts for the cab.
