Roof clearance lights
Just bought a 2017 F250 Lariat and noticed on the drive home last night the roof clearance lights are not on. I don't think there should be a switch so maybe it's a fuse or the harness was never plugged in. Any help on which fuse or harness location would be great. I did look behind the inside passenger side windshield trim(where the handle to help get in is) for a connector but didn't see any there.
Thanks for the additional info.
I found a YouTube video of a guy showing the plug at the bottom of the A pillar.
I did find the plug in the pillar. It's under some white foam after removing the A pillar cover. It's way down there but just at the base of the cab near the windshield. That plug was attached fine. It has purple/black & purple/white wires in it.
I did also pull out the glove box to allow acces to the many plugs and control modules. While there were two plugs just capped off, I could not find any location they intuitively plugged into.
so I guess it's off to the dealer at lunch tomorrow.
Bummer
Well,
After four days at the dealer they called and said "they can't fix it". They have tested everything to "the end of their abilities" and don't know what's wrong. They said everything is plugged in at the A pillar and behind the glove box. The only option now is to remove the head liner "which is above their pay grade". I can't believe one of the largest Ford dealers in Birmingham can't fix some lights. They didn't suggest to keep it longer and work on it further, they just gave up.
So now I have to give up the truck to another Ford dealer next week.
Well,
Electrical problems in my experience can be very frustrating to trace down.
The general mechanics in my world have always expressed being conflicted about justifying the shop time needed to trace down electrical problems. I can identify with the service rep on how hard this can be.
That being said, good grief, a Ford dealership should be able to handle tracing out something as simple as cab lights.
If I were given the "I give up" response from my dealer I would look for a dealer with a higher level of skill in the service department. My grandson and I could certainly pull a headliner. It might be best to be with another dealer should something really significant go wrong with the truck in the future.
daphill
06-09-2010 12:43 PM
