RRD high volume fuel pickup??
Going to be doing the hutch mod soon and while reading and browsing the interwebs for info. I came across this..Riffraff Diesel High-Volume Fuel Pickup for 6.0L/7.3L Ford Powerstroke
My question. How does this unit compare to doing the hutch mod? Seems like it'd be better plus when (not if) I upgrade injectors this unit would definitely aid in fuel delivery. Thoughts??
Honestly for your build it isn't really needed. It would more cost effective to go with a standard hutch mod in your case. Give us a call if we can help you further with your goals though.
Riffraff Diesel Hutch In-Tank Fuel Mod Kit - Riffraff Diesel Performance
I have 140cc injectors in my E99 with the FRX my fuel pressure sits at 73psi and only drops to 68-69 when I'm towing. I've read the stock pump is good to 400hp iirc, I don't think you need to spend the money unless you're building an absolute beast. I'm sure others will chime in too.
Dropping a tank that still has 10 gals / 80 lbs of diesel on your head.
Getting all that crap on top of the tank in the tank when working on it.
Dropping your PVC cutter inside the tank while cutting the fill/vent tubes.
Trying to figure out how to prove your new pickup assembly doesn't leak before re-installing it.
Spending an hour getting the fuel pickup retaining ring started on the threads
Re-installing the tank with 10gal /80 lbs of diesel back under the truck without dropping it on your head again.
Is that good enough?
The only thing I really had a hard time with was getting the line from the sender twisted properly so that when the tank was back up where it needs to be the line would not be twisted. My first attempt at putting the tank back up went well until I stopped just short to check out the hoses and what not. because I had installed the fuel line the way I did, when I raised the tank it put a kink in the line. I fixed that by twisting the line the correct way so that when raising the tank the line would be flat and straight.
I also had a bit of trouble getting the fill neck hose back on too, but that was self inflicted because I installed a port in the neck for the auxiliary tank and pump. It was not too difficult, but a bit tedious is all.
Just have a couple of jacks and at least a 2x6. I did the entire mod myself with about 5 gallons of fuel in the tank. It is really quite easy.
I did it myself too, but it was awkward. I banged my head when the tank shifted a bit and all the fuel sloshed and tipped it off the jack. After that I used tie downs to secure it to the jacks. If I had my pressure washer with me I would've used that to clean the top before working on it. My problem was disconnecting the stock fuel lines, and getting sprayed with the diesel in the lines.
I used a floor Jack to lower the tank. I put a ratchet strap front and rear of tank to keep it level while lowering it.
I used my air compressor to blow loose dirt off top and then brake cleaner to clean residue and dirt off of everything. I used a paint pen to mark the ring to match the little arrow on the top of the sending unit. So that when I put it altogether I knew the ring was as tight the second time as it was originally.
I used a 1/2" drill bit to put a mild bevel in the end of the rubber hose that I slid on the pick up line. This allowed me to slide the hose over the lip that the compression fitting would lock onto. I was able to slide the hose on the pick up tube about 3" which allowed for 3 hose clamps.
I used the ratchet straps to get the tank back up in the air so they could get the jack underneath it. And then just slowly lifted everything up .
If I had to do it over again I'd pump the fuel left in the tank through funnels with coffee filters in it then into diesel cans, wipe the fuel tank clean, then pour the clean fuel bad into the tank.
issues. I sort of question if it has been done already. I have no issues filling up to 36 gallons and my truck runs great, but I just want to know for sure it's been done and really want a Racor filter before the pump.
Speaking of, where did you guys get those filter setups? I love the fact that you can look at the condition of your fuel.
