Cold weather diesel Anti Gel
Reading the manual is state not to use any addictive. I'm assuming most Stations in the Great North (Canada) are putting anti gel in there Diesel fuel but Im not sure if that would be sufficient. I'm in Southern Ontario so our winters aren't that bad compare to some places in Canada. We may have days that are as cold as -20C (5F) but they usual only last for a day or 2. Most winter days are -5c (23F) First time diesel owner and I don't want any issues when the cold weather hits.
PS Today was 23C (73) but when the cold comes it comes fast.
on
In Canada they do add anti gel right at the pump but some times it is not enough. Pumps doe freeze up time to time.
When it's colder then -20 you really should consider it along with a block heater. While your truck will likely run it is hard on the engine. Anything colder then -20 my old diesel would not run without plugging in.
stop using power service. That is an emulsifier, you do NOT want to use emulsifier additives in the 6.7 fuel system.
on
-40 with additive is some what brave. Living in sask is totally brave. It's like standing naked in a wind tunnel while some one try's to throw liquid nitrogen at you.
I think I saw plus 6 with a wind chill of -30 once in sask.
I have seen gas gel up in a brand new Land Rover at -50. I believe the fuel does not gel uniformity so there is room plus if I recall correctly gelling may not destroy or prevent your truck from running just cause problems.
But I do know one thing. I will park facing away from the wind when it's really cold and windy.
Otherwise the block heaters are nowhere near as effective.
Diesel is a blend of #1 and #2, which allows it to handle the lower temps without gelling. It's actually waxes that cause most of the problem. #1 summer fuel, has more energy and so you get better fuel mileage however, it gels, so the lower the temps it will be used in the more #2 needs to be added.
Most commercial fuel stations list the operating temp,s it can be run, often the labels are for -10 C, -20 C, -45C, and so on. So, if your fuel is rated for the temps you will be driving for the whole tank, you don't need to add extra additives, if however, you plan to go North with that tank, say -10 C fuel. But your going to go North, then I treat my fuel. I now also need to work through how long the long box tank of 181 liters will last. Ie fueling in the fall, we could get a cold spell, so I will probably treat the next tank if the labels don't show sufficient cold temp blend. I also often treat when down south fueling up, depending on the labels on my commercial vendor, as I am going north and by the time I get home, it's often 20-30 degrees colder.
The hell it doesn't. When it's real windy and cold the engine won't ever reach normal operating temperature. That's why big trucks have radiator covers and folks used to stick cardboard in front. When parked outside, it will reach ambient temperature a hell of a lot quicker. On the other hand even an unheated shed will help keep some of the latent heat for easier starts the next day. Wind affects trucks in the same way (convection) and for exactly the same reason, it removes heat much faster.
Therefore the diesel in the tank will never be colder then the true temp (we are talking additives and fuel gelling). So again, wind chill has no effect on the conversation at hand.
Sorry but you are wrong. If it is -5 outside with a constant wind chill of -30 and you go start the truck, the truck will never be colder then -5 regardless of wind chill. Inanimate objects are never colder then the true temp outside (-5 in my example). Therefore the diesel in the tank will never be colder then the true temp (we are talking additives and fuel gelling). So again, wind chill has no effect on the conversation at hand.
What it DOES do, wind carries away whatever heat has accumulated much, much faster. It's going to reach whatever the ambient temperature is, a whole lot sooner. See the difference?
That's why we wear clothes to protect our skin in high wind, and that's why if you park your truck outside in high wind it will reach ambient temperature much faster than with no wind.
