Do I have windowmakers?
Can someone tell me if my grain truck has the split rims that are bad?
Is this picture good enough for you to tell?
One of the tag axles has a tire without much tread left.
I’d like to replace the tire on the tag axle. It’s 8.25 x 20
If this is split rim, then I probably should replace the rim.
How does that work?
Can I just buy a different style rim from a salvage truck?
The tires on the main duals on the back are good, I believe.
Thank you!
How does that work?
Thank you!
Your left front is a locking side ring style. Should be safe if unhurt. The forward tandem is a Dayton demountable, which will never have a widow maker Firestone RH-5° rim. The RH-5° was used exclusively on Budd type wheels. The rear Budd isn't clear enough to tell. Better pics of it, and the other side of the truck are needed. Plus you'll need to show us the inner duals on the rear tandem. Stu
alecs
33
10-20-2014 08:33 AM
Shadowrider123
05-15-2014 05:19 AM
HateTank
22
03-29-2007 02:07 PM
mc
12-08-2004 10:05 PM
