Pressure plate and clutch help
Trying to get my rebuilt clutch adjusted and I ran into a problem. I seem to have to much travel on the throw out bearing before it makes contact with pressure plate fingers. The fork is over half way through the bell housing opening and by the time time it is even partially depressed, it "bottoms out" against the housing. I already have the adjustment rod down to the lower end of the adjustment threads. Any ideas?
I would have liked to compare the rebuilt pressure plate with the old one, but I bought it back it January and it is long gone. I went back to the Clutch and Brake shop and they have no idea why it would be like this. It is an "11 inch disc and they said they thought they were all the same in these series of trucks. I left with both of us scratching our heads. My truck is a 55' F350. Maybe it is an odd ball like many parts on my truck?
There is about "1 of free play before it makes contact with the fingers. So the fork starts out a little more than perpendicular to the bell housing.
Hopefully one of you guys with the bigger trucks can help.
Thanks Ross. I've been wondering about that. Do you know what the original thickness might be? To late in the day to check now, but will definitely be checking in the morning.
Pappawheely
05-30-2018 08:04 AM
53fordman1
09-29-2015 10:05 AM
KingDogfl
08-21-2011 10:08 AM
teardropty
03-10-2011 04:04 PM
