Gtp38r exhaust flow
Gtp38r exhaust flow
01 7.3 238-80% sticks, gtp38r,gearhead tunes, fuel system and 4" down pipe 5" straight exhaust.
I did the ebpv valve delete but just plugged the holes in the exhaust outlet. Is the Garret outlet any better? I know turbonetics makes a bigger one just wondering if it will lower egts that much? I'm trying to get spool up a little quicker/ lower egts. I have some horrible leaking up pipes so I just bought the bellowed up pipes so while I'm in there I'm wondering if getting a new outlet would be worth it?
The Garrett blank outlet is the same as the EBP outlet, they just pull it off the production line before the valve holes are drilled. It probably would not make any noticeable difference in EGTs. The smooth bore of the outlet does enhance the flow of exhaust simply because it does not have the interior holes that disrupts the flow. How much easier the exhaust flows out of the blank outlet would take more diagnostic equipment than what I possess.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
my low tune which is my tow is almost smokeless and it's towing. Yeah I have to go to a t4 mount to get a bigger turbo which is kinda why I haven't done it yet.
Big sticks and chipped - yeah... it'll get white hot if you let it. My EGT gauges go up to 1600, and I don't know if your gauges actually read 1800, if you're estimating, or if it's a typo - but that's not important. What matters is you are configured to burn down the motor if you aren't very careful.
If this was my only viable vehicle, I'd grab for the mildest tune I have and not get in the habit of passing people. I have an alternate vehicle, which I would drive in your case - until those exhaust leaks are eliminated.
I hear ya. I'm planning on the same injectors but I'm having them tuned for my turbo until I can upgrade to a t-4 mount and bigger turbo.
F-SUPER DUTY
28
07-28-2008 01:05 PM
