No Water Out Of Fresh Water Drain
I just winterized my truck camper. When I went to drain my fresh water tank, nothing came out. I ended up using the onboard water pump to drain it. I'm thinking the drain line is somehow blocked? ... or the valve is not functioning as it should?
The drain valve plumbing comes out of the fresh water tank in the basement at the back of my truck camper and it is only about 1 foot long. You can visually inspect the entire drain line and there is no obvious problem. I was thinking about "snaking" the drain somehow but have never done this. What suggestions do you have?
Received 6,667 Likes
on
Just my experience with them,
Steve
Steve
Not at all unusual, if you are depending on gravity to drain the system (which I do not recommend). Don't expect to get much out of some of them unless you are going to blow out the system under pressure. It just can vary a tremendous amount. I never worried about it, winterized hundreds of campers, and never had a problem. I never relied on them because I knew I could never trust them. Either use an air compressor or pump RV antifreeze through your system.
Steve
Steve
The drain on the tank is not called a "low point drain". It is simply the drain for the tank and is not connected to anything else. Is there water in the tank? I would guess not. If you run the water pump does it pump water? Using an air compressor to pressurize the system will have no impact on that drain if it is connected only to the tank.
Steve
Steve
on
I am having the same issue with my fresh water drain on my Jayco. I was dumping the tanks to lighten up the trailer to put it on jack stands for tires and bearings. I haven't looked into it in depth yet, but it seems something is clogging it. I left it open and it kept dripping slowly for a day or two, not sure if the tank is actually empty yet or not as I just continued on.
I'm planning on sanitizing my water system this weekend to get ready for a Thanksgiving boondocking trip, so I'll update on what I find. I'm assuming it will be a simple fix as it's just a 4" length of hose with a valve connected to the bottom of the tank.
I have low pressure 40 or so PSI blown the lines and have done the pump down method. It was fine either way. My SoP was close off the Hot water By pass. Drain down the hot water. Remove the 2 plugs (tank and the low point) and kick on the pump until empty. Re cap and pump just about 3 gallons of Marine/RV -50 F A/F through the system. I tend to start at the further point of the lines which is a spray hose connection in the back the trailer and work forward to the bathroom which is right next. Tub sink toilet. Then to the kitchen and check the water pump as I have the A/F filler port there. Add a bit to the drains. I use about 2 1/2 gallons on my 30 footer. My dad uses about 2 gallons on his 15 foot hybrid.
I was suggesting you get underneath the camper, remove the drain cap, and blow into the drain line. If anything was in the tank that has settled over the drain hole, this should clear it away and allow the water to come out full stream (at least until it gets plugged again).
This applies equally to a truck camper.
