Van dying at 1/2 tank 2000 e350 5.4l gas
So the past 2 times my tank has gotten almost to 1/2 a tank. More like just under 3/4. The van has suptered till it dies, exactly like it would if it was running out of fuel.
Both times I coasted into a gas station and filled it up, about 12 - 13 gallons both times and it runs perfectly fine.
I pulled the codes last time and it was p0232 but it had actually shut down while driving.
where should I look first.. I REALLY don't want to drop the tank. 1st time it happened was on a long drive. Last time it was 20 min into a 30 min drive.
This a regular cargo van, or club wagon?
Should have a 35 gallon mid-ship tank?
Your only filling up with 12-13 gallons, about a 1/3 of the tank.
Must be a problem with the intank fuel pump/pick-up. Maybe the sock filter is plugged up or folded up?
I've had fuel pumps go bad, where you could drive 20-30 minutes, and it would sputter and spit, and pulling off and letting the pump cool down, from over heating, got me back to home base, for a pump change out.
Next time this happens, let the van sit for about 20 minutes, and see if it re-starts and runs, that will tell you the pump is shot.
You sure your getting a Code 232?? = 232 - PCM Detected Coil 1, 2, 3 Or 4 Primary Circuit Failure (EI)
Yes, my van has the 35 gal tank
It's a chubwagon
It instantly restarted after I fueled it. Couldn't have taken longer than 5min.
Yes I am getting P0232 - P0232 High Voltage Fuel Pump Secondary Circuit
I am worried it is the sock filter plugged up or something the only strange thing is that it happened with the exact same fuel used. It would mean I'd have to drop the tank.. no fun.
It's a chubwagon
Is there any way to test the pump to see if it is going bad. Like I said it runs perfect until it gets to about 2/3 of a tank. Then acts EXACTLY like its out of fuel. It sputters along until it finally dies.
Question: Could a vacuum leak cause some of these problems?? The vacuum diagram seems to indicate that the fuel pump/tank is tied into the vacuum system. I have had codes that indicate a vacuum leak and also when giving the van hard throttle the AC vents go to the defrost mode, indicating there is a problem with the vacuum system or a leak. Any thoughts?
Just saying........not all parts are "perfect".
Few of us have posted our experience with this, giving you a quick fix to your problem, you could keep reaching out and grabbing straws to solve the problem if you like.
Plus, this is another reason that you should not let the tank get lower than 1/4 full, as the gas keep the pump cool while it's running. Proven fact.
Not really, what your looking at is the "Fuel Gases Vapor Re-circulation system"
Yes, the engine vacuum provides "suction" for this system, but it is not tied into the actual engine vacuum system. If the rubber vacuum lines (and plastic lines) become cracked/rotted, leaking, that's a issue to address also, as you might notice some senors not working correctly, or a high idle cause by a "vacuum leak"
If your experiencing a defroster mode at hard throttle, then you do have a vacuum leak, or a problem with the blend door servo motor, which operates from engine vacuum, OR a problem with the vacuum storage canister leaking.
Not to be a turd in the punchbowl, but in my long life I have seen a couple fuel pickup lines break off part way down...so the part of the tank below the break is simply not picked up.
Remote chance, but there it is...if it is the case then rust is probably present and you need a new tank.
That being said i am in TX and rust is not something we really deal with down here. It would seem something like that happened though.
His problem seams to be an overheating fuel pump, that's shutting down after driving some time (20 minutes).
