Rear seat question
There is not latch to pull installed from the factory on the driver side. There is an aftermarket latch kit you can add . https://www.builtrightind.com/produc...r-seat-release
not much back there but I did add the latch for mine if I need to get back there.
Otherwise if you raise your back seat bottom, it will move the seat back away from the back wall and if you look down there you can see the release pin.
I had the dealership drop the the seat. Left it down until I returned home. Took out a small drill bit. Drilled a small hole through the rod attached a split key ring holder. Pulled out some 5/50 cord and made a loop. Closed the seat looped the 5/50 cord around the backseat headrest. This way I never loose the puller.
This video is on the Builtright site, it may help you see how it is done. They offer a 10% off for veterans, with free shipping.
https://youtu.be/mPsC1a3uIb8
