Spare tire advice
Spare tire advice
Hi:
Feeling my first driving is just around the corner, it makes me realize that I don't have a spare tire on my list of remaining items. I'm running 16 x 650s on the truck. My question is, could I run a smaller tire as a "get me home" doughnut kinda spare to save space? Say a 16 x 500? I'm thinking the smaller tire might be easier to stow behind the seat (gas tank moved to frame) or maybe even under the frame somewhere.
Thanks,
John
Thanks,
John
While you could probably get by with a smaller tire, why would you want to?
If it was me, I would source a rim (if you don't already have one), get a matching tire, and source the tire carrier and bolts/nuts, then install the spare under the bed in the rear where it is supposed to go.
There are several people who have, or can get you the proper carrier for a reasonable amount. If your hanging hardware is MIA, unfortunately the bolts are no longer available. However, they can be pretty easily fabricated, and there are still some dealerships that have the nuts in stock. The nut parts number is 51 1476-A.
Assuming your avatar is your truck, it looks like an F-1. If your fuel tank hangs down low enough to obstruct the mounting of the spare I can see why moving it inside has merit. Also it might be easier to access from inside. The under frame hangers are a p.i.t.a. unless you use a modern crank up type. If you go with a smaller tire on the spare rim be aware that tires get shorter as they get narrower. Driving any distance like that wouldn't be real safe. If you can't fit a 6.50" in the space behind the seat, is carrying it in the bed out of the question? Stu
Is hiding the spare tire important ?
I thought of using a "limp mode spare" behind the seat but opted for full size tire so that I could drive longer road trips with confidence.
I mounted mine in the front of the bed, with an after market spare tire holder, that is bolt in.
It works for me.
It works for me.
The smaller tire idea is great is theory and lousy in practice due the size issue that Stu mentioned. With the relocated fuel tank and dual exhaust set up on your truck, under frame isn't going to work either. I'm not optimistic that you'll have room behind the seat.
It would seem that you'll need to have some sort of bed mount or never leave the comforts of your road service coverage area.
on
Mounted mine flat in the bed and put a black vinyl spare tire cover off a Jeep over it. You could not even tell it was in there unless you walked by and looked in the bed. Since I had 5x4.5 in front (Volare) and 5x4.75 in the rear (Chevelle) I carried an adapter so I could put the spare on either end. There was room under the wheel to keep the adapter, an extra set of lug nuts, a lug wrench, and a bottle jack. Fortunately, I never had to use it but it was there mainly for peace of mind...
I had TWO flat tires on my recent journey to Kentucky. My tires were new, and before I left, I bragged that I hadn't changed a tire in 30 years. I was pretty sure I didn't need a spare. I found out, however, that there's a reason modern tires are tubeless, and back in the day people sometimes carried more than one spare on a long trip.
Jim
Jim
Jim
Jim
John
Just to be clear; I didn't have 2 flat tires at the same time. I had a flat--changed it--and had it fixed. Then, several days later another tire was going flat. For that tire, I was able to get to a tire store for a fix without breaking out my spare. In both cases, there were holes in the inner tubes. I'm thinking modern shops aren't so familiar with dealing with tires with tubes.
Jim
Jim
I think the trick used to be to slightly inflate the tube as the tire was being installed, and to check that the tube didn't get pinched in the rim.
Behind seat
I saw a older truck where they mounted a dummy spare behind the seat but they had to cope out the floor and recess the spare into it.
If you go the in bed route, drilling the holes into the front lip of the bed can be tricky. Watch you don't scruff the paint on the front panel.
The top of my mount anchors to the top of the front panel. I could take a couple pictures if you like to give you food for thought.
Did some research for you on inside bed spare mounts. They say LMC makes a mount for the side, but it's for a Chevy truck but it might be adaptable for our Ford trucks.
Here are two links where they discuss it.
1958-1959 fleetside tire bracket - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Spare Tire Mount - In Bed - The 1947 - Present Chevrolet & GMC Truck Message Board Network
