Tried everything
Tried everything
1995 E350 7.3 hard/no start when warm
new idm
new fuel pump (2 to be exact auto zone gave out bought a ford one)
2 new batteries
new under valve cover wiring harness
new injector orings
new glow plug controler
new fpr
cleaned the fpr screen
New ipr
new cps
it runs great, but if i shut it off cold i am done...hours before it will start...
new idm
2 new batteries
new injector orings
new fpr
New ipr
new cps
Thought I’d share this as I was having issues starting cold then it got to where it eventually wouldn’t start at all sounded like it was cranking good enough but anyway it was battery connections long story short they looked good but there was lots of corrosion in between the terminals cleaned them up and truck fired right up I really didn’t think it was the issue because it literally sounded and seemed to be cranking over fine anyway good luck to you man I’ve been in your shoes more than once with my truck
I had slow cranking causing my start issues, here is some other places to clean up in this thread
https://www.ford-trucks.com/forums/1...ou-cranky.html
