blowen turbo pipe
Brake or carb cleaner on the boots to remove all of the oil
residue before the hairspray. Also clean the pipe ends too.
EDIT : Was just thinking. Rubbing alcohol will also work. What you are trying
to do with it is get a clean dry set of surfaces to put the hairspray on
and then stuck together. One trick is while the hairspray is still wel
the parts will slide together. If you want till it's dry things will be sticky.
