Bad coil?
I think I got to the root of the problem. We had the carb and fuel pump rebuilt and I installed a good coil. Truck ran real nice - for about 15 minutes and then it started running badly again. After we got it home we disconnected the fuel line at the tank valve to check for flow.
Nothing. Zip. Not a trickle. We blew some air thru the valve and the fuel ran as normal.
Any suggestions on how to thoroughly clean the fuel tank?
i steamed clean mine and , put a chain Inside and shook it as best i could . done that for a few hours,until nothing came out. then i sent it to a old guy who had some red stuff to cover the Inside. the name of the product i,m unsure but the empty can is at the shop. suppose to seal pin holes and seal up all the loose rust scabs.i did use it afterwards but not much. its sitting empty in my garage.
flipklos
05-10-2011 10:07 PM
cliffordingles
13
03-08-2011 10:38 AM
Freightrain
04-19-2004 06:24 PM
