More power, need help!
Better Breathing
I am assuming the engine is in good mechanical condition, and can support a little more HP and Torque. 300K is a lot of miles. The best way to get more power from a factory Ford is to improve it's breathing. For the budget you are talking about, you should be able to buy a decent set of aftermarket aluminum heads with bigger valves and smaller combustion chambers (if you do the work yourself). This, along with a set of headers will make your Ford breath much better, and raise the compression, if you get smaller combustion chambers. I am sure there are other options, but this is where I would start.
on
What axle ratio does it have? Anything less than 4.10 is fighting an up hill battle you won't win. The next best upgrade after gears is a cam swap, new heads are almost a complete waste of money until the factory cam is changed... it really is that bad.
screaminford
Performance & General Engine Building
04-20-2012 04:12 PM
Scot Clark
04-21-2008 11:38 AM
crack
12-12-2005 08:34 PM
scott9320
06-11-2003 04:39 PM
