Rough Country 2", Ready Lift Track Bar Relocate Bracket, Carlie Sway Bar Brackets, Specialty Products Caster Camber Bushings. It looks high in the front in the Pic but it's still has a 3/4" lower Rake in the front.I also changed the rear main leafs to a parabolic main leaf and re-arched 1" lower. The main leaf added 1000 Lbs per Rear spring. I can hook up my dump trailer and load 3 pallets of sod with out squatting. It still rides very smooth.
Oh wow, legit setup right there. I'm considering leveling the front and I have bags for the rear which I've used on every other truck with great results.
