2009 F-150 5.4l very slow
Hello all, new guy here, I have a 2009 f150 5.4l with 255,000km on it, engine is out of a 2007 f150 and has around 180,000km. my issue is this:
under acceleration the truck is very slow, it takes a long time to get up to speed, like I'm pulling a huge trailer behind me, engine sounds good other than the diesel sound that we all know and love, truck also shifts fine.
the following have been replaced in an effort to fix the issue.
-brand new cats and manifolds
-spark plugs
-air filter
-fuel pressure tested good
-no misfires/no engine light or codes
I have taken it to a ford dealership and they plugged it into their laptop and did a diagnosis, they didn't find anything wrong but agreed with me that it should pull a lot harder than it does.
any ideas would be greatly appreciated!
-spark plugs
-air filter
Well, I guess it depends what you are comparing it to, and what rpm you are letting it rev up to while accelerating.
That engine never did win any races, but when it was running well it pulled strongly in the high rpm range. Despite the few people in the Triton fan club, that engine has done a lot of work in so many applications.
The newer engines are miles ahead in power, economy and speed. I know none of that answers your question, but there may be no answer.....
I guess here's the test, if you have a freeway on-ramp or similar situation, what happens if you put your foot to the floor and let it rev up to redline on shifts? Does that feel faster to you, or does it seem to fall on its face?
If you have a obd2 adapter and a phone you can download forscan lite or forscan for windows and view the data in real time for fuel flow, air flow, throttle body position, pedal position, etc. That might lead to what is happening and why you aren't getting power.
The 2009 might be limited in what it can view but you should still be able to get some of that information out of it.
SideWinder4.9l
17
03-06-2013 06:04 PM
toyotajeep
03-14-2006 09:28 AM
