Over heating?
Over heating?
Howdy,
My pick up is a 1985 f150 Lariat, 302, automatic 2WD
My pick up has been sitting for a year and half (last tag date) and I just got it road worthy, but I think it's over heating
My temp gauge is the stock one and looks like C-NORMAL-H
After cruising for a bit it likes to alternate between the A and L
Is this normal? I do have the original radiator and I have installed a new thermostat
Thanks,
-Matt
Thanks,
-Matt
Are there any other signs of overheating? Pinging when you press the throttle? Burning oil smell? Coolant running out? If not, I would forget the factory gauge and put a aftermarket set of gauges on it with real numbers under the dash. A lot of money can be wasted worrying about the stock gauges and what they say. The fuel gauge is the only one to worry about and keep working.
It was loosing coolant, but after I fixed a coolant leak it has stayed full. As far as I can tell the only symptom of overheating is the temp gauge. The only gauge that doesn't "work" is the Fuel gauge Lol; I'll look for an after market tempt gauge
btw, the thermostat I installed was rated at 195 F, would it hurt to put in a 180 F?
Thank you Dave,
-Matt
Thank you Dave,
-Matt
Thank you Dave,
-Matt
Thank you Dave,
-Matt
Update:
My over heating troubles are over and this is what I did:
I did not replace the factory temperature gauge
I did replace the thermostat (195F), gave it a complete radiator flush, and put in new antifreeze.
After those 3 things my needle likes to dance between the R and the M on my gauge which looks like this C-NORMAL-H
Also, there were little white ***** in the older (still green) anti-freeze, whats up with that? It didn't look like oil, it looked like little bits of Styrofoam were floating around in there
martinbarrio
10-16-2017 08:15 PM
Da_Lariat_Chariot
06-28-2016 04:01 PM
tjbeggs
18
08-31-2007 01:43 PM
firedudecndn
08-17-2005 05:06 PM
