Starter Bolts Striped out of housing - What TAP to use
Hello Fellas,
my starter came lose from the housing and I tried tightening the bolts but one was missing and the other just kept going round and round. I took the bolt out and it had metal shavings stuck in the threads. I cleaned the metal out and placed it in the other hole but it just went round and round like the other one.
Now to tap and use new bolts. Does anyone know of a kit that has a tap and new bolts?
What have others used? If no kit, what Tap and bolts to use?
Many thanks in advance
BBD
BBD
Heli-coil
I was hoping that someone has done this before on a 7.3 and could kindly give me some sizes of heli-coil and bolts.
Thanks again,
BBD
Possible issue with this is when your starter goes out you have to re drill the new starter. Won't be easy to do if you are traveling when the starter goes out. Most people pack enough tools they could change their own starter but I don't think most pack a drill and bits with them.
I don't recommend heli-coils either. I would use a threaded insert, which does require the original hole to be tapped much larger. This would retain the original size starter bolts.
Time Sert for thread repair
I have M10x1.5 for my starter bolts with the 8.8 hardness.
I would like to know if I could just drill through and insert a long bolt and bolt the starter on and add a lock washer or two?
Thank you,
BBD
Update
I stopped at a salvage yard today and they had a 7.3 laying on the shop floor. I noticed that the starter bolts onto a aluminum plate around 1 inch thick. Since the bell housing for the trans bolts to the other side there is no way to install bolts from the back side.
When a flange bolt has this tip, does anyone know the name for that ?
I plan to look for a good quality 3 bolt starter.
the Denso (excellent starter by the way) ripped out my threads after 2 years because it is a beast.
BBD
