Oil pan drain plugs discussion
I've seen people on here using the Fumoto valves, not sure how I feel about them. The other option I'm more likely to go is with a magnetic drain plug, I would also replace the crush washer with oil change. I've used and am currently using these on other vehicle I have with solid results. Keep in mind if the magnet is picking up large pieces more than fuzz you likely have some internal issues. I went ahead and included links below to the Fumoto valve, GReddy and Mishimoto magnetic drain plug.
One thing I do like about the GReddy is the flange on the bolt head it self, serves as a solid place for the crush washer.
https://smile.amazon.com/dp/B003T7XU...=1Y4EQ5SOF11EM
https://smile.amazon.com/dp/B008OZFP...d=1Y4EQ5SOF11E
https://smile.amazon.com/Mishimoto-M...J9MRY9HQ2HPH5S
Just like to keep up on any abnormalities that might crop up, and yes I start the oil flow when draining and wait a few seconds and collect it as its flowing as per the lab's directions.
I also have the Fumoto. I have the one you have pictured with the nipple on it. Best choice you could make. So easy to change the oil. I attach some clear tubing to the nipple then the other end into my container. With the clear tubing I can see the oil and watch for anything unusual. I also attach a magnet next to the drain. I remove the magnet when I drain the oil, then replace. I have used mine for probably 5 years with no issues. I have been through deep mud and snow with no issues.
WolverineXcursion
01-18-2018 09:12 AM
2009kr
2017+ Super Duty
08-01-2017 12:34 PM
superduty4x4
21
07-31-2008 12:38 PM
