So, sometimes, the Overdrive Off light starts blinking, but, doesn't always stay blinking. Sometimes it stops, within a few miles. Ant thoughts, as to what might be going on ?
Yes, I know what's going on. Something is wrong with the transmission system. To find out what's wrong you need to get the codes read. The places that read codes free usually cannot read these codes. You need either a good independent shop or a Ford dealer.
You've heard from the experts here already, but is it possible it's just a bad toggle switch in the shifter? Between mark and subford they will have the answer. Rule/step number 1 is to check the codes like they said.
