Replaced fuel pump on 75 F100 360 and in doing so messed up oil pressure sending unit. Replaced the sending unit and now have no oil pressure! Any thoughts? Have current to unit. Thanks in advance. Bruce
no clue, really. at least not ZERO ohms (complete short). If you can, see if you can hook a wire to it, and connect up the ohm-meter to ground and the oil pressure sender, and when running, it should fluctuate with RPM (oil pressure).
Don't be surprised if it's defective if it's an off shore replacement. Buy, borrow or steal a mechanical gauge to screw in temp to verify your pressure..
