Max towing capacity
Max towing capacity
1993 f350 7.3 turbo diesel. Single cab 8 ft bed srw. 4:10 gears stock suspension with a 5spd. Max towing capability. I'm only curious. I read mixed things so I have no clue what's accurate. What is the max trailer weight capacity? And what is the max load to have as for weight on the rear axle and tongue weight?
My '96 manual only lists a 4x4 regular cab F350, and zero diesel applications, but it should be comparable to a 460. I have a feeling that the diesel tow ratings came in the Diesel Supplement Manual.
Max GCWR for a 4x4 F350 manual 460 4.10 gear is 16000 lbs, and max trailer weight of 10400 lbs. If you want to increase that to 18500 lbs GCWR, and 12500 lbs trailer weight swap out the manual for an E4OD.
Received 3,090 Likes
on
on
This is right from the Ford Recreational vehicle and trailer towing guide 1992-3....
The GCWR of the Fseries trucks towing a frame hitched trailer.
F series with 7.3 and automatic is:
355....12000lbs
410....17000lbs
F series with 7.3 and manual is:
355....12000lbs
410....14000lbs
The CGWR of the Fseries trucks towing a Fifth wheel trailer.
F series with 7.3 automatic is:
355....12000lbs
410....17000lbs
513....18000lbs
Fseries with 7.3 and manual is:
355....12000lbs
410....14000lbs
513....17000lbs
355....12000lbs
410....17000lbs
355....12000lbs
410....14000lbs
355....12000lbs
410....17000lbs
513....18000lbs
355....12000lbs
410....14000lbs
513....17000lbs
on
I haven't seen a hitch rated for anything more 1600 lbs tongue weight.
Max tongue weight is determined by the gross axle weight rating and the gross vehicle weight rating. You shouldn't exceed either of them. Load your truck with whatever your typical load is then take it to a CAT scale. Subtract your scale weight from the gross weight on your door jamb sticker, if you get weights per axle subtract the weight of the rear axle from the gross axle weight rating on the door sticker. The lower of these two values is your max tongue weight.
AKHunter93
27
05-09-2016 04:42 AM
BlueOvalLover
06-30-2014 05:00 PM
sstarnes
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-04-2004 06:42 AM
Okie DRN
07-27-2002 09:28 AM
