08 Explorer w/o gas cap P0442 4.0 v6 4wd
Just started driving my new to me 2008 Explorer.
No light on but scan it and keep seeing P0442 pending code.
I see it as small leak in the EVAP system.
Have not seen any real common causes or anything as I search for ideas.
Curious if anyone has had similar trouble.
It is 4.0 v6 4 wd XLT model.
There is no actual gas cap on it so I am wondering if this is cause...?
Looks like a pretty heavily spring loaded "flipper" inside the fuel fill neck and rubber gasket around the access door.
Seems to be intect but can't help but think it would top the list of possibilities.
OR, does it not have any effect on the system and/or code??
Appreciate anything anyone might be able to offer.
THANKS ! ! !
THANKS ! ! !
Found this since asking here too:
Will look at cleaning the filler and gasket I guess.
See if that helps.
Otherwise maybe add a locking insert....
https://howtune.com/articles/316-tip...ller-on-a-ford
Ford added capless fuel filler technology called Easy Fuel™ to most of its cars starting in 2008. It's a Ford exclusive technology that eliminates the fuel filler cap.
The idea is designed to simplify fill ups, reduce emissions (evaporating gasoline), reduce incidents of using the wrong type of fuel, and protect vehicles from theft.
That said, there's a specific method you should use to fill the vehicle. Typically theres a pretty simple sticker on the filler door that covers the technique, but we'll cover it here.
What makes it better:
Faster fill-ups with no cap
Prevents filling up with wrong fuel type
No cap to lose or forget
No check engine lights from improperly tightened gas caps
Significantly reduces harmful fuel vapors in the atmosphere
Tamper resistant seal reduces siphoning and vandalism
The Trade Offs:
Over filling can vent a lot of gas vapor. Stop filling when the station's pump clicks.
The tamper resistant seal means you must carry a special Ford-provided funnel to use a gas can.
If it fails, replacement costs will be higher then just a new cap.
There's a new fill-up procedure to follow.
Early versions are especially sensitive to dirt and debris.
It's more important that you close the filler door to keep the capless filler clean.
Fill Up Procedure
These capless fillers usually have a special instructions on a sticker applied to the inside of the gas door. The procedure is simple, but apparently important enough to warrant instructions. The instructions are pretty simple:
Release the pump trigger when full
Wait 5 seconds
Pull the pump nozzle out of the filler
Troubleshooting
A common problem (especially with the earlier designs) results in the car throwing a P0442 engine code. Many times, this is caused by the flap in the filler neck not sealing completely due to dirt. Some models like the 2009-2012 Ford Fusion seem particularly vulnerable due to the filler's location and door design.
Make sure the filler is clean and clear of debris. Spray it out with compressed air, add a light spray of oil, and use your gas can filler neck to actuate the flapper 10-20 times.
Clean the filler door seals that prevent debris from entering the filler
Check the filler door spring (if it has one) to make sure it's keeping the door shut.
Test the purge valve
Using a Gas Can
Vehicles equipped with this type of filler all come with a special filler funnel needed for use with a gas can. The neck is typically located in the spare tire area under the floor in the truck or rear of the truck. Grab the neck, insert fully it into the filler neck and use it like you'd use a funnel.
Add A Locking Cap
Despite being tamper resistant and generally maintenance free - you may wish to add a locking cap to add another layer of theft prevention and help keep dirt and debris out of the filler neck.
There are several changes to these caps over the years, make sure you look at the reviews and choose the correct cap for your application:
Ford OEM 8U5Z-9C268-B
Stant 10524
MotoRad MGC-913
See if that helps.
The Trade Offs:
Fill Up Procedure
Wait 5 seconds
Troubleshooting
Using a Gas Can
Add A Locking Cap
Stant 10524
MotoRad MGC-913
Nhudsonrapp
07-23-2013 01:05 PM
spinnr
09-01-2011 08:13 AM
