E4OD mated to 400
E4OD mated to 400
I'm not sure if this is the correct place to post this, but here goes. My project continues to take on a life of its own after seeing other's builds. I'm contemplating matching up an E4OD to my 400 for highway drivability. I am currently planning on 3.73 gears so thought the OD trans would help cruising down the highway. Anyway, I can't seem to find much info on whether this will work. I know I have to get the aftermarket electronic controller, which is expensive.
Has anyone done this? Will the C6 bell housing work, or do I need a modified bell housing for an E4OD? Can the E4OD be built to handle my torque goal of 500 lb/ft? I presume a stock E4OD cannot handle that power.
Are there any other suggested OD transmissions to mate with the 400?
Thank you.
Thank you.
I did not know that...I haven't pulled my 400/c6 combo yet. Thanks for the info. I believe the 400/460 have matching bellhousing pattern so I can search for one of those.
I'm doing the same thing, and my 400 peaked at 500 ft-lbs on Tim's dyno. But I haven't chosen the E4OD yet, so will follow this thread.
However, I am concerned that the flywheel on a 400 is about 3/8" further forward than the one on a 460. That means the torque converter will slide forward on the splines that much, and there may not be full engagement with the splines. But Tim sells a spacer that moves the 400's flywheel back to the 460's position, and I am planning to run it. And, with that a 469's starter can be used.
Thoughts?
Thoughts?
wookbigalow
02-25-2010 10:52 PM
rockdawg84
10-14-2007 01:53 PM
oregon250
10-03-2002 10:08 PM
