Brake Master Cylinder 1955 F 800
The original number for the F-800 (except tandem) master cylinder, Model QH, in 1953 was TFAA 22141-A. It was changed to B3Q 2140-A which is also then correct through 1956. It might be correct for later years too, I didn't check those books. Neither of the numbers are found on Parts Voice. Bill might have other leads. Stu
Part number for a '48-'50 is 7EQ2140. Probably the same for a '55 maybe. 1-1/2" bore. 7EQ-2140-A | RearCounter.com | 1 found at 1 seller
Here ya go
WAGNER F17681, FE16186, FE17681, FE-17681, FE17692 MASTER CYLINDER NEW | eBay
And
https://www.napaonline.com/en/p/NMAM14025?interchange=1
The B3Q-2140-A
Crosses over to
E14025 Eis Brake Parts
40240 Tiffin Parts Llc
14025 Echlin Inc
F17681 FEDERAL MOGUL CORPORATION (Wagner)
MC14025 C E Niehoff And Co /Trw Inc (Raybestos)
M17681 Airtex Products
And it carries an active NSN (NATO Stock Number) of 2530-00-006-6259 So some sort of NATO piece of equipment in service is still using it, to keep it stock-listed with an active NSN
And
The B3Q-2140-A
Crosses over to
14025 Echlin Inc
B3Q-2140-A .. Master Cylinder / Obsolete
No Ford dealer or obsolete parts vendor has any.
A8Q-2004-A .. Master Cylinder Repair Kit-Use without Tandem Axle / Obsolete
1948/52 F7/F8 (Conventional) // 1953/56 B700/750 School Bus; F700/750/800/900; C700/750/800/900 Cab Forward.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
Note: The kit fits all the above, the B3Q-2140-A master cylinder does not.
I try my best answer Darrell: Problem is most people go by say the Ford
part no. which is no good, all mfg. stamp their own part no. on a a part,
Ford did not mfg. master cylinders or wheel cylinders, these were from venders.
Most likely from the low bid, like Lockheed, Wagner, Bendix for example. Back to
my loader a 1964 Trojan. Its part no. is like 14 digits long worthless, Ford no.worthless Pretty sure it was a Wagner cylinder. I measured the thing and
some how I found Wagner web site with pictures. "bore, bolt hole dimensions" and
got their part no. went to Napa and had it after noon time. For giggles, I ask Steve
Napa with his computer, whats this fit? and he said you got the time? from IH Dodge
Mack Ford and a million fork lifts loaders and on and on. So yes the Ford number is obsolete, but does not mean the part is. just the Ford number is. Then when I got
it- identical to the F800 it now has a Napa p/n ? go figure, number games?
what ever you do, is not to go to Napa and say 55 F800 with a Ford number or a big
What !!! so go to Wagnor site or get a kid to do it LOL.....sam
dcarnut1
09-02-2008 03:56 PM
fatfenders
09-14-2002 10:08 PM
