1996 F-250 Disposable?
I have a 96 F250. the rear fuel pump went out and it took me a while to replace it. in that time the pressure switch/valve that switches from one tank to the other seized up. there are NO wires to this valve is aparently pressure activated only. the fuel lines from both tanks go to thes junction (6 hoses, 4 in 2 out) the feed lines from the tanks this valve and up to the fuel filter connection seen to be all 1 piece. It is NOT available from; Napa,LMCtruck,Ford deallership or anywhere else I have looked. The Ford dealership told me that this part is "nolonger available through dealership" So I asked him if the 96's were "disposable" If no longer suported through them and he said YES. Babbit ford Flagstaff AZ. These are all high pressure hoses with those funkey snap in / special tool to remove lines so cannot just cut the jct. out and clamp in another. anyone know what I can do to regain the use of my rear fuel tank? running on just 1 16gal. tank is a real pain on long trips, and when I go out into the woods................ I have to bring gas cans so I dont get stuck way out off the road. this 460 REALLY LOVES FUEL.
Ok so if this union in just a free flowing junction and the check valves are in the fuel pump. I just installed a new pump in the rear tank and still the truck will not run from that tank. I did bench test the old pump and it did not respond to being hooked directly to a batt. I did the same with the new pump and it did spin. also I can hear the pump pressure up when I switch the selector on the dash after being installed, even when I start the truck on the front tank, as soon as I switch over to the rear tank the truck quits. There must be some sort of gate in there or how would the return line get the unused fuel back to the correct tank? I could try to get a photo of this union and post it. might be kinda hard as it is half way down the leingth of the front fuel tank inside the frame rail.
Do you have a fuel pressure gauge? As I've said before to many others, just because a part is new does not mean it's good. It sounds like either your new pump is weak OR you have a leaking valve in your FRONT tank that is allowing the fuel pressure from the rear pump to bleed off into the front tank. You can rent a fuel pressure gauge set from places like Autozone or Advance or O'Reilly's, or just buy one of your own. A basic kit is pretty cheap and they're invaluable for problems like the one you're having.
And don't fret, a 96 F Series truck is about the farthest thing from being a throw-away vehicle. Well, unless you were one of those that believed cash for clunkers was a good program. If you do dispose of it, I'll come pick it up free of charge!
not miswiered
I am sure that I wiered it correctly even more I was not happy with the crimp style connecters that they prdvider with the pump so I soldered them together just to be shure.
I have a pressure guadge for low pressure lines but not for efi system. I will get one next time i go to town, I am assuming there is a port where I can insert it into the line. althow I am shure there is not anywhere between the tank and the jct block so it must be up under the hood. how would I know if the fuel is going into the other tank like someone sugested it might be?
I just got A complete Napa SKF kit, Koyo bearing and two Forsheda seals in an apparently updated design (eliminates floating grease baffle?) for that same $50.
These duel tank issues seem to be the norm, I'm sure you will get it figured out!
Im not sure if this is the part your looking for but i found this on rockauto. It says it the fuel tank selector valve.
More Information for DORMAN 911000
