2013 Ecoboost Temporary Loss of Power
Hey,
I have a 2013 F150 with a 3.5 Ecoboost. I was pulling my 16' aluminum boat on a two lane road and pulled out to pass another truck. I stomped on the accelerator and the motor lost power. I limped back into my lane and noticed the engine light blinking. If I had to describe it, it seemed like the motor was running in some sort of "limp mode."
After about a minute or so, I let up on the accelerator and the light stopped blinking where the motor began to run normally. Although I only "stomped" on accelerator once since I had the issue, I haven't had the problem since.
I did not bring the truck in for service..Any thoughts what this could be and any suggestions would be appreciated. The truck has 44k on it..
Tx,
448AA
Tx,
448AA
Hey,
Tx,
448AA
Tx,
448AA
Howe many miles are on the truck? This sounds very much like a spark plug misfire. The ecoboost engines are hard on plugs. Mine had to be changed at 62K miles for the same reason. Later on the #2 coil went out out, no issues since and I'm now at 76K miles on the clock.
Hey,
Tx,
448AA
Tx,
448AA
If you have a drill bit case full of bits, get the 1/16th bit and see just how small the hole would actually be. It's nothing more than a weep hole.
I drilled mine about 10K miles ago after I replaced the plugs and boots and the #2 coil went out. In my mind I needed to be able to mitigate and rule out any further misfire type of issues. No issues with boost loss, nothing of any real value came out of the hole but I can see a small oil stain on the back side of my air dam. Obviously something is coming out, at least intermittently but it's not going into my intake, that's for sure.
For those who are spooked about drilling the hole and fear boost loss or something getting in (which is impossible) then turn a screw into the hole or add a petcock. This will allow you to control when you open the hole and drain the CAC.
Or, just do nothing and run it hard periodically to keep it cleaned out.
I agree no one having done the weep hole has reported any noticeable drop in performance. There is even a YouTube video that shows a minimal drop in boost. And that small hole won't suck up anything substantial. But it will pull in a small amount of dirty air. I personally wouldn't do the weep hole if I was regularly around dirt roads.
palmers
1997 - 2003 F150
12-20-2006 10:28 PM
