Do you have a spray in bed liner that is causing the problem? I had to work on each one a little bit and the fit is tight, but they pretty much went right in...
I have the liner but it doesn't seem to bother anything. I see that little seam on the cleat that's in between the gap, is that the part that you filed off?
I lightly filed all the groves and slots that slide into the bed mounted cleat. Their was some plastic mold forming burs at least on mine, and that worked. Key must be in cleat when mounting and maybe a little oil lube might help to slide jn place. Good luck
