Loose Steering
First step is to make sure everything under the front end is nice and tight. Ball joints, tie rod ends, track bar bushings, etc. Anything that controls the front tires needs to be looked at carefully. Also have someone turn the wheel while you are looking at everything. You might be able to spot where the play is. A lot of the time it's in the steering box. You can sometimes adjust them, but not everyone has good results with it. However, everyone that I know has had excellent results by swapping out the steering box with a Redhead, when the steering box was the problem.
Hi all, jumping on this as well as I seem to have the same problem. I've replaced everything under the front: ball joints, tie rod ends, track bar, new steering box, etc. Have to replace my power steering pump but found that, while digging in there to replace the steering box, the lower end of the steering shaft where it connects to the box, is what has the play. I can't seem to find that part anywhere though, anyone have ideas?
Being as I have tried everything else, the steering box is next. The local Ford dealer replaced my steering box with a new(rebuilt I'm sure) steering box. That made it worse. I would like to do the Redhead at some point. If you are talking about that area where the wheel is centered and then you move it left or right and nothing happens this is your likely culprit. You are always on guard as natural drifting from road contours makes the X move, you never know how much to move the wheel without overcorrecting. I had the front end checked 3 different times by 3 different shops plus my own hands on inspection. Usually front end components will let the vehicle drift a lot when you are holding the wheel straight with no movement as will alignment. However, that's not the issue. It's trying to steer while having to constantly pay attention to any movement you make versus driving down the road, paying attention, and making minor intuitive corrections. It's very tiring to drive. Tightening the gear box only gives you more resistance while you steer in the dead zone ( an oxymoron I know). Anyway, I've come to the conclusion that the steering box is the issue in light of my previous X and this one. I would not put my money toward anything but a Red Head. Just my $.02.
I haven't had it checked yet since I live in the wilderness. Will be moving back into civilization in a month or two and will get an alignment so I can sit and watch it. I even have center hole shims if needed. The thing is that it's not that it's wandering around much because this one doesn't. However, if the wind blows on the flat plains, it moves you around. Also, the roads out here have quite a crown to them and the lanes are probably legal width by an inch. There's not much room for error. I can be on a flat straight area and hands off and it tracks straight. It's just that when I do have to make a correction, I'll move the wheel an inch or more and nothing happens. Then with a bit more wheel movement- suddenly the steering reacts so I can end up overcorrecting. So I am making a correction and having to be really careful with moving it just enough. That's what's tiring.It's like there is an area of steering movement that is just dead. There is no feedback or feel in the steering in that area. It's also very very easy to move the wheel within the confines of the dead zone. So-easy-no feedback-no movement and then the steering engages. I agree with the 5+ degrees caster. It's just that any off center movement of the wheel requires extra care. I'll definitely be getting it aligned long before I have my pennies saved for a redhead. I will dance with joy if that fixes the steering issue.
