Centech Fuse Panel install
Hello. I started a similar thread but didn't get much response. I started this Centech panel install and I'm starting to think it would of been easier to just install the whole harness. But anyways I'm already into it. I have a few questions maybe I can get some help. And thanks.
First off it appears that a lot of the wiring gets tied in from other sources, ignition switch, light switch. So basically I need 3 sources to get this going, battery(constant power), accesory(for acc mode in switch), and ignition.
I just cut the original panel out. There are 9 wires. Once you connect the black/yellow the truck will start. I'm trying to figure out were I can get the other modes, acc and ignition?
Black/yellow always has power=battery
Red/white has power in both acc and ignition modes.
I need to get power during Accessory mode and power during Ignition mode
Let me try to be clear. Once I can get power at acc then I can tie in the those fuses. When I get power in ignition I can tie in those fuses. And battery will tie in the other fuses. Battery ties in about 4 fuses, acc ties in 4, and then ignition will tie in its 4 fuses.
Once I figure this I can start to reroute and clean my stock harness up. A lot more hacking then what I thought. Bare wires too. I might of prevented a fire.
Appreciate the help. I've searched the net but couldn't find much.
Thanks
Kenny
Thanks
Kenny
Sounds like you got it right. One constant (battery) and two switched sources (acc/ ignition). The constant is just straight to battery+ and the acc and ignition can be pulled from the back of the keyed switch.
Centech makes good stuff. I put one of their panels on a '62 Falcon, but I did choose to run all new wires. I opted to make a harness rather than use a kit. For me it was simpler to go clean sheet rather than fish through the existing wires.
Edit:
I didn't see part of your post. The acc source should power lights, radio etc., without power to ignition.
Edit:
Edit:
Edit:
I found black/red has power in both cycles ignition and accesory. This is where I'm getting confused. I was hoping the original panel would have 3 cycle, Battery, Accesory, and Ignition but that doesn't seem the case.
So should I pull power from ignition to the Centech box? I'm thinking I should go from Centech box and starting feeding other sources. I'm probably not making sense that's why I'm lost
Thanks again
Kenny
Thanks John.
Thanks again
Kenny
Thanks again
Kenny
Yes I got that too. Sorry for my ignorance here. I will keep searching and try to figure this out.
I'm pretty much thinking that because the original fuse panel is so small that the harness was designed to get power from the light switch and ignition switch. Sound right?
So now I can remove power from those switches and feed them through the new Centech panel.
My accesory cycle should also be found in the ignition switch? So remove from there and run to the Centech and then back out?
The original ignition switch has 6 wires and really only needs 4, battery, acc, ign, run?
Whew not sure. My heads spinning. This is probably easy for everyone but man not me
Thanks again for the help
Kenny
Kenny
Kenny
Kenny
I agree with you about the original wiring, that's why I bought Centechs Bronco ignition and headlight switches. It all made more sense and a cleaner job for me that way.
As far as ignition source You don't remove it from the switch snd put it on the panel, you run a wire from the IGN post on the back of the switch to the IGN post on the panel.
So basically the battery goes to the switch. The switch determines acc and ign modes. So the switch feeds them to the panel? Haha confusing.
I will get this. I would also buy those switches from Centech but I want to get this tied up tomorrow
Kenny
There is an accessory post on the back of the switch and a run post on the back of the switch. Just connect acc on the switch to acc on the panel, and run on the switch to run on the panel.
Just keep the questions coming it's no bother.
Ok somethings wrong, besides me
Not sure if this is right. My Ignition switch works like this
In OFF only yellow has power
In IGN all wires have power except red/blue
Red/blue gets power only in RUN and all wires have power
In ACC on yellow and black/green get power. The problem is black/green gets power always but OFF
I can't find ACC power.
I'm lost. I would expect the Ignition switch would have power separate during ACC and IGN cycles. Do I have a existing problem or what am I missing?
Thanks again
Kenny
Thanks again
Kenny
Thanks again
Kenny
Thanks again
Kenny
When you say IGN are you saying the start position?
The black/ green is a switched source and should work fine for acc connection on the panel, so long as your coil wire is dead when the key is in the acc position.
what year is the truck?
I'm working on the ignition switch. I'm trying to figure that out. I'm thinking that I need to pull power from there to the Centech panel.
3 wires from the ignition switch to the fuse panel and you're in bussiness.
Not necessarily. If you study the panel outputs on the RUN and ACC circuits you'll see that there are functions that should have power at either position.
