cps change
07-27-2017, 05:09 PM
on
cps change
changed my cps and still show no rpm's. can new sensor be bad
07-27-2017, 10:14 PM
John, welcome to the forums. Was the new CPS a Ford or International one, or was it from a parts house? Parts house CPS don't seem to play nice with these engines. Use a Ford or international one only.
07-28-2017, 06:40 PM
on
The new cps came from the Ford Dealer. Installed and still no movement of tach or start.
07-28-2017, 06:57 PM
on
I'm new to diesels so am floundering a little here. Truck ran fine one day and the next no start. Internet said try new cps first and that if it was working should show some rpms on tach while cranking. New cps, no rpm's on tach. I have a 1997 f350 crew cab dually. I'm lacking a little in the mechanical department, but any help you can give me will be much appreciated. Thanks in advance John
07-28-2017, 08:38 PM
look at the wiring going to the CPS really well. if it becomes worn the signal can be interrupted and it will not start.
Do have a check engine light?
Smoke from the tailpipe while cranking?
07-29-2017, 12:27 AM
FIRST - does the WTS light come on?
07-30-2017, 02:00 PM
on
I will check the wiring tomorrow. I do not have a check engine light and I have not noticed any smoke. There is a WTS light. Thanks John
07-30-2017, 02:21 PM
07-31-2017, 02:34 PM
on
I did check wiring on CPS. Seems to be ok. Thanks for the link ! It seems simple enough that maybe even I can Follow it.
cabloom300
32
03-13-2013 07:14 AM
1969fordguy
05-12-2008 02:45 PM
99powerstrokeSD
20
06-19-2007 05:39 PM
Jay-re
04-15-2007 05:33 PM
Joe98684
03-09-2006 04:11 PM
