Code P0442 on 2003 V10 - common?
CEL turned on this morning heading to work. Truck drove completely normal with no signs of altered performance.
Stopped by Autozone after work and they checked it with a code reader.
Came back with P0442 - "Purge Valve Solenoid"
Part sold with or without bracket ($104.99 or $94.99).
Is this a common part to fail?
How can I be sure it has truly failed?
Is it acceptable to reset CEL and see if it fails again? If so, how do I reset?
Where is part located?
Thanks!
Thanks!
A P0442 DTC does not indicate a faulty "Purge Valve Solenoid", it indicates a small leak in the EVAP system. That means that the fault could be anything from a gas cap that didn't (or can't) seal properly, a vent solenoid that doesn't seal, or any other small leak anywhere in the evap portion of the fuel system.
it could be even a small leak in the 50 plus feet of lines.
try replacing the gas cap first.
to reset computer .. disconnect the negative battery cable for 5 minutes.
as parts stores.. will say "WE" can not clear error codes.. it the law.. but its NOT.
Great info guys. I appreciate the responses.
My pops has a reader that clears CEL. I'll borrow his.
New gas cap and I'll see if that's the issue.
Since there are so many possibilities, is it a process of elimination....starting with the most simple and moving to more complex?
If so, that can get expensive, especially when many of these parts can not be returned.
Example.....if not gas cap, what is the next part to consider replacing?
Thanks
Thanks
the quickest way to find the issue is a "Smoke Test".. there are many feet of hoses and tubing involved, any clamp broken... hose cracked... and then the evap control valves and canister ..
they inject man made smoke into the evap system.. and look for smoke to exit..
Lady across the street just had it done to her Chevy.. replaced cracked canister/control valve for $485.00
for this problem.. the smoke test is the cheapest way.. that is why the gas cap is replaced first.. and most common to trigger that code.
the evap system.. just be able to maintain a small level of vacuum.. gas tank, 20 plus feet of hoses and tubing and other parts. reason a very small leak is a big deal.
Do make sure you use only the correct Motorcraft gas cap, aftermarket ones can be hit or miss.
Finding out if the repair was effective can take a considerable amount of time. The EVAP monitor is tough to get to execute even when following the prescribed drive cycle. I've seen ones that have taken literally months to run. If you have an upcoming emissions test, be aware that an incomplete evap monitor, by itself, is usually not a disqualifying or failure event during testing.
This is not a common failure on your vintage of Super Duty since only the California/OBDII calibrations have the evaporative emissions system. The rest of the country (except the "green" states that required California-certified vehicles) got Super Duties without this (and a few other) OBDII requirement. Check the emissions label on the underside of your hood to see what calibration the vehicle has.
spinnr
09-01-2011 08:13 AM
4.0 Beast
09-25-2006 11:13 PM
