360 FE rebuild cambearings
Old 07-24-2017, 05:28 PM
hanseriksson's Avatar
hanseriksson
hanseriksson is offline
Hi
im rebuilding a 360 for my f 250 truck and have a question about the 1st cam bearing .The new cam bearing that goes in to number one spot(front) has to holes and a grove between them there is also a grove going 90 deg from one of the holes and i cant figure out if that it supposed to go towards the thrust bearing plate (front) or backwards. The old bearing did not have this grove
Hans
Old 07-24-2017, 07:05 PM
john jamieson's Avatar
john jamieson
john jamieson is online now
you will ge more responces on the FE forum
Old 07-24-2017, 07:16 PM
wyrm73's Avatar
wyrm73
wyrm73 is offline
There was a fairly extensive thread recently about FE engines and cam bearings. Might want to give it a read too.
https://www.ford-trucks.com/forums/1...s-2-times.html
Old 07-24-2017, 10:25 PM
hanseriksson
thank you will do
wyrm73
11-28-2017 10:40 AM
Lisa Convey
03-02-2016 06:27 PM
1975FordF250
04-19-2014 09:34 AM
mlf72f250
06-20-2003 11:04 PM
Quick Reply: 360 FE rebuild cambearings
