Turn signal switch?
Turn signal switch?
Hey guys, I need someone to verify something for me. My truck is a 78 f150 2wd 6cyl standard transmission. My right rear brake light/tail light is acting up. If I hit the brakes it just goes out vs getting brighter and when I use my left turn signal it goes out as well without me hitting the brakes. The right turn signal works fine. I remember in another vehicle I owned the brake lights run through the turn signal switch. Is it the same on this truck? Is there a flasher fuse that could cause this? Thanks guys
Grounds. Remember, turn signal circuits run to both ends of the truck... check all the grounds at both ends, and check that the sockets themselves are connecting to ground - it is not unusual to find you have just cleaned off the sheet metal and ring connector, to discover the wire to ground strip connection inside the socket is crap. Make sure these are 100% before going into switches or flashers.
There are TWO flashers.
Both flashers look identical, are round with two prongs, but the 4 way flasher is a H/D type, has a louder CLICK.
T/S flasher plugs into the back of the instrument cluster at the upper left.
4 way flasher nestles into a bracket that attaches to the backside of the dash (near the cluster) w/a screw.
