Wiring up manual glow plug switch
So I bought new silinoid and controller and if the truck is cold the relay will stay on and it will do what it supposed to do and heat the plugs and the problem is the relay clicks on and off when it's summer 95+ outside and it takes forever to start because it's not staying on I'm guessing that's the clicking so anyways I said screw it and started to do manually setup I got my wiring diagram from diesal hub
So i followed this and i put a inline 30 amp fuse between the switch and the small terminal it connects to and im getting voltage on the silinoid side of the fuse but not the other side of the fuse so my manual switch aint working yet i also grounded to the frame if you want pics of my set up to help me let me know thanks
Jon
Jon
Received 3,090 Likes
on
Ok so I got the manual switch to work and it fired up first try using it I will probably make where the controller controls the glow plugs and use the switch when I need to I only have it wired where it's running from my manual switch only because I know I have autocrap plugs still so that's why the gpc didn't work properly so imma get the right plugs next pay day you think the autolites will last for 2 weeks lol
on
bluemtn95ford
13
10-22-2015 07:05 PM
rmalottwtes30
12-13-2008 02:56 PM
