Parking Brake went down to floor
on
1993 F250 7.5L. Just left for vacation, stopped at the big yellow candy store in Jordan, MN. When I stepped on the parking brake with truck running from the "P" position the pedal went to the floor and felt "loose". I turned the truck off and tried again and the PB works as normal. Also now works with engine running or engine off. Any ideas?
This is a known problem with these trucks and there is a recall for it. For whatever reason the pawl for the automatic parking brake adjuster fails to engage with the sector gear and that is why the pedal went to the floor. Fords fix is to install a wedge that prevents the pawl from disengaging from the sector gear. The auto adjust does not work with the wedge installed. There is a TSB that tells to remove the wedge then apply and release the parking brake six times to adjust them reinstall the wedge.
Cummings Guy
10-08-2017 04:28 PM
