Selecting Wheels For 2WD Street Truck.
My truck is a useful hobby. Kind of a hotrod with a (open air) trunk.
It's all personal taste that I don't expect anybody to share, but I've always liked white on white wheels/body color. Hence the AR-44s I slapped on when bought.
I like a plain, smooth uncluttered, straight, 5-spoke design.
If I had an ideal, it would be 99 Cobra wheel (and yes, I'd powder coat them white):
So now that I'm about ready to pull the trigger on "new shoes" I've been FUTILELY searching for a compromise amongst the GAUDY BS that passes for truck wheels these days
First limiting factor is the 5 on 5-1/2 (139.7mm) bolt circle.
Second is the bore size that clears the axle hub. (3.435"/87.25 mm) My measurements, don't know the actual "factory" numbers.
You can find a few 5 on 5.5, but the bore size kills the deal.
So I'm asking: Does anybody know of a clean, uncluttered 5-spoke design other than the ones I've had to PASS on because they don't get past the bore size that I'm missing?
That list includes:
Torque Thrust D & all the variations.
Crager GT (my #2 desire, but no larger than 5 on 4.75)
AR 200s & US Mag's 200s knock-off (probably my favorite design), bore too small.
So far about all I've been able to come close to liking is Level Eight "Punch".
A light gray center with polished lip, one piece aluminum. Don't care for the fake bead lock. And I'd really like a little more negative offset.
Mostly impossible on a modern design.
That list includes:
Did ford ever have a universal spare rim? By that I mean a rim with 5x5 and 5x4.5 patterns? I know GM did a friend of mine had one and used it bolted to his Caprice rotors and drums. Then punched and drilled the small 5x4.75 into his 5x5 rotors and drums then popped the studs out and moved them to the small pattern holes to run Fbody rims on a B-body. He had a local machine shop clearance the wheels for the larger bearing hubs as well.
Maybe you could run the cobra wheels if there is enough meat to machine them?
The Cobra would be too weak when it comes to side loading, I just like the style. Clean, straight lines with a little rounding & plain, hard painted finish.
Killer look by the way.
Did I mention I've about talked myself into moving up to a 17" rim?
As if I don't have enough obstacles already. By the time I wear this next set of tires out, 15" are going to be only available through Corker (Coker?) & $$$.
US Mags makes this 200S knock off in a 18 x 8 or 9.5 on 5 X 5.50... but 72.60 mm bore:
It's a 91, I think.
Thanks. Front wheel is a 17", rear 15"
Don't know. My AR-44s aren't, they have a center bore diameter of 108 mm.
Just found a Torque thrust 18" that shows a bore dia. of 87.10 mm with me measuring my axle hub at 86.75 & my stock spare opening of 87.25
Aren't there some Jeep wheels that are the same metric size as the 97^ F & Expeditions?
Oh, its a 150. But not a 94.
