What is this on the orfice tube?
Since its been so hot I've decided to restore the dead air conditioning system. This system hasn't worked since I bought it but it is complete.
It appears the P.O. attempted to charge it with R134 without changing anything of the old R12 seals . It didn't work.
I removed the orfice tube and it is clogged up with this mystery gunk. Does anyone know what this is? Compressor shavings? The oil is clear.
The clutch works (when 12v applied directly) and when I spin the pulley, a little pressure is felt on my finger plugging the manifold hole.
Is my compressor toast?
Thanks in advance.
There was alot more crud on here until I dropped it (whoops!)
Thanks in advance.
There should be a debris screen at the condenser discharge. Crack open the fitting between the battery and radiator. Tucked inside the condenser tube you should find a cone-shaped screen. Take a look at that and let us know what you find.
Hmmm... Definitely not in there. A quick online search reveals no info. Does anyone know where to get this condenser outlet filter?
Are you using an aftermarket or OEM replacement? I hear the larger aftermarkets perform better w/ R134A, but don't fit quite right.
Also, I noticed some damage underneath my condenser...Does this look like a leak.?
The fins in the 12 o'clock position look punctured but no oil
Then again, maybe this filter was eliminated by 1986.
I just picked up a Spectra 7-4150. Looks to be a reasonable fit, but there's a tube that sticks out too far from the edge at the base of the passenger side. If I increase the bend of the lower brackets about 3/4" (should be easy), that will bring the bottom edge forward far enough for the offending tube to clear the radiator support. Too hot in the afternoon sun to get very involved right now, but I do plan to post a product report in the next few days.
If you follow the outlet of the compressor, it goes to the condensor in front of the radiator. If you think your compressor or one before it put junk in the system, the first place it hits is the condenser. It has to go all the way through the condensor before it makes it to the orifice screen you pulled out.
How much is a condenser? Since yours is damaged I would replace it. If you don't have the money and want to test it, I would plug one end with my finger or something, and put a rag and a air compressor on the other end and put some pressure on it and see if it leaks. I know compressed shop air is not good to put in a A/C system, but it's all I have and I have done it several times on different cars with no ill affects. When I do use compressed air I always put a vacuum on it and leave it several hours to a day to make sure it pulls a good vacuum and gets any moisture out that I may have introduced.
Any replacement Condenser sold today is R134a compatible. It may be true that a AC specifically designed for 134a will have some improvement over the R12 design, but I have not heard of anyone that could not get a good working AC system using a replacement Condenser sold as a replacement for the 80-86 models. Of course the fit is dependent on the company making the unit.
If the 94 model is a replacement and a direct fit, that is good to know. I would like to know what makes the 94 design better than the 80-86 design (more rows, bigger tubes, etc.)?
EOTZ-19B958-A .. A/C Receiver/Dryer Outlet Tube Filter / Obsolete
1980/89 F100/350.
MAPLES FORD in Warsaw MO has 2 = 660-438-5110.
MORLAN-SHELL FORD in West Plaines MO has 2 = 417-256-3195.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
Shown as basic part number 19B958 in pic in post #4.
1980/89 F100/350.
1980/89 F100/350.
Thank you sir!!
Or was crud created or concentrated by the cooling action of the condenser, and thus the outlet was the best location?
Discuss amongst yourselves...
1980/89 F100/350.
1980/89 F100/350.
