rewire 55 f100 with EZ wire kit
Old 07-21-2017, 02:53 PM
MIBill's Avatar
MIBill
MIBill is offline
ready to rewire. Cab is mostly bare. Need to drill holes firewall, etc. firewall was filled. hanging brake pedal. debating running wires to back under cab in the frame rails? wire to courtesy light along top in door frame with returns for ground. wires to front lower than original but not hidden as some have done. It looks like it will be real busy under the dash when I mount the 21 circuit mini fuse block. I was thinking of mounting it left of steering column, but have not ruled out a center mount. Also, any downside to mounting it in the engine compartment other than looks? On the one hand, I would like to keep it simple, I am 72 and I would like to keep access easy, but, I would still like it to look fairly clean. Bill in SW MI
Old 07-21-2017, 04:56 PM
RingoRaintree's Avatar
RingoRaintree
RingoRaintree is offline
I pretty much did the same. Low cab exit, ran along frame front and rear, engine harness low in middle. Very little showing but not extreme. I would say that putting fuse box on right of steering wheel was much easier and will be a lot easier to service.
Old 07-21-2017, 05:03 PM
49willard's Avatar
49willard
49willard is offline
Bill,
To start with, we are the same age. I used the same EZ wire kit on my 49. I like a clean firewall also. I mounted the panel to the left of the steering column in the cab and up just out of view. In my case I hid the wires by exiting the cab in the upper corner of the toeboard where the kick panel ends. It drops down from there to the inside of the frame rail. I boxed the frame in the engine bay such that it becomes a conduit for wires going forward. I will say that changing a fuse if required is a hands and knees operation, a bit awkward.
Old 07-21-2017, 06:49 PM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
Mine is above the steering wheel. I can get to it, hands and knees, of course, but routing, from there, was easy. I did not, as the instructions say, remove all the lines I do not need, (AC, electric windows, etc.), instead, I saved some and hid them behind the kick panel. Now I still have some line for any expansion.
Old 07-22-2017, 07:04 AM
artscott61's Avatar
artscott61
artscott61 is offline
MIBill please take plenty of pic's. I have an ez wire in it now but it is a mess and a friend of mine that builds this stuff said to get a new one and start from scratch. I will find a pic and show you all. In the mean time I will follow this Bill get it done then come do mine wiring for some reason scares the hell out of me.
Old 07-22-2017, 04:59 PM
Greg Rogers's Avatar
Greg Rogers
Greg Rogers is offline
I will be following along also. I am probably going to have to start all over with my truck.
Old 07-23-2017, 05:49 AM
Marten's Avatar
Marten
Marten is offline
I'm not there yet but had a friend suggest that if you build a small plate, put it on a hinge and mount it to the bottom of your dash you can then let it drop down to work on it and when done pivot it up and out of sight. Seems simple but have not seen anyone do it.
191124x7
2017+ Super Duty
01-11-2019 02:40 PM
hail destroyer
07-12-2017 10:16 AM
Don Vito
02-04-2016 06:11 AM
Diesel Newb
03-12-2013 12:03 AM
first_f250
1999 to 2016 Super Duty
05-13-2009 10:51 AM
Quick Reply: rewire 55 f100 with EZ wire kit
