autolock hub not working
Well just replaced most everything in the front axle. Hubs, vacuum seal, dust seal, inner seals and calipers. I also cleaned the autolock hubs. Fist time I used them they worked. I tried again today and no 4wd. I checked the vacuum lines and they are all intact. Not sure what to do next.
Suggest you "T" off one of vacuum lines to hub with a vacuum gauge.
That will tell you if hubs are still leaking or if they are getting vacuum.
Easiest way to tell if hub is leaking is to blow into vacuum line to hub. If you cannot blow thru it's good. If you can is bad.
The gauge will also tell you if vacuum solenoid is working right or not.
If you have a 7.3L, turn your keys to the "on" position to power up your vacuum pump to fill the line. That will allow you to track down the leak.
Stewart
On my last ex there was a valve where the vac lines meet and go to the hubs. On a 7.3 its on the passenger side between the pump and the battery, high on the fender. Mine was bad, replaced it and they worked fine.
Its got two vac hoses and an electrical connector. Can't remember the name of it now, pretty cheap to replace too
