i need some advice.
Old 07-20-2017, 05:14 PM
lilorbie's Avatar
lilorbie
lilorbie is offline
i need some advice.
i have a 67 f-100 240/tott. i am going to swap in a 302/c-4. my cousin has a 68 f-100 360/390 auto. factory air con. and it also has power steering.will the power steering be a direct swap. i know that 67,s have some one year only stuff. how much if any of the wiring on the column will i have to change to make every thing work. both of these trucks are 2 wheel drive. thanks in advance for any help with this.
Old 07-20-2017, 06:11 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
The T/S switch is the same 67/early 69. So no wiring issues. The 68 P/S has the less desired Bendix P/S box. Is it leaking yet?
Old 07-20-2017, 08:49 PM
pchelp's Avatar
pchelp
pchelp is offline
Grab the pulleys off that 390! You'll need the two grove water pump pulley and at least a two grove crank pulley. If you guys aren't going to use the let me know I'll buy them.
Old 07-21-2017, 05:57 AM
lilorbie's Avatar
lilorbie
lilorbie is offline
JEFFFAFA thanks for the help. i can,t tell if its leaking or not because there are so many rat turds you can hardly see any thing. i told my cousin . you better power wash this thing quick.
Old 07-21-2017, 04:17 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Sounds like your cousin needs to get a male and female feral cat. So they can keep up with the rats.
Old 07-21-2017, 04:43 PM
lilorbie's Avatar
lilorbie
lilorbie is offline
JEFFFAFA he has plenty of cats and dogs as well. he just bought the truck about 3 days ago. for $400.00. to bad its a long bed . i know some people like them . but for my self i like the swb. better. he wants me to buy it for what he paid for it. i know that Ford used two diff. steering boxes on these trucks. what should i look for to tell them apart.?
Old 07-21-2017, 04:52 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
4 BOLT TOP COVER OR 2.
Old 07-21-2017, 06:12 PM
lilorbie's Avatar
lilorbie
lilorbie is offline
JEFFFAFA thanks for the pictures. this site is awesome with all of the knowledge from the members here. if you have a question someone on here has already been there done that and are willing to help.
SuperSabre
01-15-2011 07:47 PM
mmuenchow
13
11-10-2006 02:34 PM
67buckeyeF100
01-13-2006 10:11 AM
jowilker
04-07-2000 05:14 AM
Quick Reply: i need some advice.
